Home > Technical (L405) > 2016 AB Cornering (edited not Turning) Lights
comports
All,
I'd like to check something with you if I can - my AB has almost eveything but i noticed (or rather was told) that I don't appear to have turning lights.. (the ones that illuminate when the steering wheel is turned)
Should they be standard on these cars, what exactly do they consist of as I've compared mine to a pals car and cannot see anything different in his light cluster, even though he has them and I don't.
Is it perhaps something that needs to be endabled via IID..?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #683777 24th Jan 2024 3:44pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening comports,
You should have a little icon light up on dash on start up yellow symbol of headlight with arrow pointing both ways, if its an Autobiography then it should have. You should also note it when driving as beam direction moves. Also on mine if you open the bonnet it will say on white sticker on headlight unit
DrF
Post #683810 24th Jan 2024 9:07pm
