L322 Range rover 2006 v8 ABS issues | |
I have been getting HDC faults and it occurs randomly but when i do a slow u turn to the right it almost always lights up a HDC fault with the EAS saying is it lowering.
Today I put a new sensor in the right front and as soon as i started the car is set off the above faults. My GAP tool read the following
Using IIDTool BT V3.0 B2803
TCCM-Transfer Case
U0122-87 (2E) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
( on 05-04-2024 12:47:15 at 146835 km )
TCM-Transmission
P0500-00 (2F) Vehicle speed sensor A
( on 05-04-2024 12:47:17 at 146835 km )
VDM-Vehicle Dynamic
C1A94-13 (08) Front right wheel speed sensor circuit - General electrical failure - circuit open
C1A94-65 (0B) Front right wheel speed sensor circuit - Algorithm based failure - signal has too few transitions/events
( on 15-04-2024 15:19:31 at 146964 km )
There was a random problem now it is when you start up So the only change is a new sensor (ebay )
Any help please
