Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 Rod Knock |
aupshon Member Since: 09 Jan 2024 Location: Cornwall Posts: 7 |
Oh it would seem i've bitten off more than I can chew with this particular engine.
10th Jan 2024 11:19am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1220 |
I would try removing the serpentine belt and then running it to see if the noise is still there. |
10th Jan 2024 12:03pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1377 |
I agree. It looks like the sound is almost coming from that smaller second pulley you can see spinning in the video. That pulley looks like its rotating in time with the sound ... the larger pulley ( I presume the crank pulley ) doesn't look in time with the sound.
10th Jan 2024 4:07pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Agreed. Whip off that belt and see how it sounds Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th Jan 2024 7:44pm |
Alrighty, what an ordeal. Had to order a couple of tools but I have managed to whip off the belt and started it up for a bit. Same situation, quiet and smooth at first, then the knock starts coming.
13th Jan 2024 12:52pm |
Left side when you're in the car or standing infront of the car?
13th Jan 2024 1:28pm |
Left side when standing in front of the car. Where is the injector pump located? |
13th Jan 2024 3:17pm |
Alrighty so put everything back together. Did the whole bleeding process etc. checked the oil filter again and I could definitely see some glitter. I reckon the engine is toast and a rod is very unhappy. Now to decide whether this is the parts car or donor car. |
14th Jan 2024 7:22pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3251 |
That’s very unlucky on a 4.4, very unlucky. 2012 TDV8 Vogue (L322) |
14th Jan 2024 7:57pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Yep, that noise is very familiar. Sounds like it is coming from the top left ton of the engine but, in reality, it's the rods screwing up the crankshaft.
16th Jan 2024 1:34pm |
Do you know what the clearance specs are and tightening sequence for bearings?
16th Jan 2024 3:25pm |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 162 |
OP - where in cornwall are you? - I'm pretty sure there was a 4.4tdv8 near me that needed work (not engine) on the cheap...I'm up on the moors near Minions etc. I can see if I can find out where it was if needed... Neil. 2010 L322 Autobiography Black Edition
16th Jan 2024 8:49pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 569 |
I've seen bottom end rebuild kits around using new parts for under £3k if you have the means to do the work yourself.
16th Jan 2024 9:06pm |
I am based in Falmouth but happy to travel/ have delivered. If you could link me to that one that would be awesome.
17th Jan 2024 9:48am |
