Home > Maintenance & Mods (L322) > Central locking not working on passenger front door 2006
DirtyDaily
United Kingdom 2006 Range Rover Vogue 4.4 V8 Galway Green
Hi all,
New owner here and so far really enjoying the l322. One thing I've noticed is the passenger door isn't locking or unlocking with the key or interior button. Window works and the lock works when pushing down the button on the door and opens when pulling the handle. Seems like a simple issue with the actuator but wondering if there is anything I should be checking first?
Tia
Post #681634 1st Jan 2024 3:55pm
ChrisandandieP
Australia 2009 Range Rover Vogue TDV8 Bonatti Grey
Did you manage to resolve your door locking issue?
My drivers door is doing the same. Suspect the actuator or whatever it is.
Post #693056 21st May 2024 10:57am
DirtyDaily
It was the actuator. It's just part of the latch system, very easy to change! I got it from a breaker.
Post #693060 21st May 2024 12:58pm
Change it before you find your door deadlocks in the closed position and the only way to open it might be a disc cutter! Big Cry
Post #693095 21st May 2024 11:29pm
