![]() | Home > Technical (L322) > Air Suspension & GAP IID Diagnostic Question |
Pull the relay for the height control and check for any drop overnight. If it's not dropped it's a calibration issue. If it has dropped you have a leak. Are you using the 'guided' calibration method? If so this has a misleading command at the end ( which I can't quite remember) but which can end up with it not saving the calibration. I have checked this by going into custom height adjustment and it will ask to update the new calibration. 2012 TDV8 Vogue (L322) |
ApeRunner Member Since: 16 Jun 2022 Location: Oxfordshire Posts: 13 ![]() ![]() ![]() |
Thanks for your reply. I used the guided process which suggests the final ‘send’ command stores the calibration but you never get to use any ‘send’ command. I’ll try the manual method if it stops raining and pull the relay this evening.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 459 ![]() ![]() ![]() |
hi did you get this problem sorted in the end ? |
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 16 ![]() ![]() |
following. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 638 ![]() ![]() ![]() |
I'm no real expert on the suspension but simple process of elimination it's unlikely to be the compressor as it's only 1 corner.
I’ve got a valve block rebuilt for the rear ,hopefully get it fitted this weekend.raise to off road height pull the relay and see it looks the next morning fingers crossed it will be sorted ,if not then air bag or airline like you said |
Sorry for slow response all, been out of country for a bit and Rangie suspension has taken a back seat.
Hi,
Thought I’d post the resolution to this now it’s fixed after giving up my diagnosis and handing over up the professionals. A local RR specialist diagnosed and fixed the problem in 4 hrs. The black air pipe going from the connector block in the NSF wheel arch to the OSF strut had chafed against the Rangey’s body under the front bonnet scuttle at 2 points, generating pinhole leaks. All sorted now and nice to have her back! |
