Home > Technical (L322) > Battery drain test procedure
camcc
Phoenix wrote:
Yes, you need to disconnect the brown cable from the body after you have set up the multimeter as a parallel ground path and obviously after the vehicle has shut down for >30 mins. I would also suggest pushing the door, bonnet & tailgate latches to their closed position (but with the doors open) so that you have full access to the inside of the vehicle without activating any of the door latches which will, of course, wake up vehicle systems.
OK so this is my drain after all systems have gone to sleep. The only thing I didn't do is lock the car (assuming that doesn't matter?) I latched the doors anyway and made sure all lights are off.
Am I right in thinking it should be under 0.05 ?
 2005 L322 4.4 AJV8
Post #680667 18th Dec 2023 5:36pm
Phoenix
Post #680668 18th Dec 2023 5:44pm
camcc
The car has only been on the drive with a brand new battery for two days, not driven except for the 30 mile drive I took it on after installing the new battery. The battery reading yesterday afternoon was 12.5V and today 24 hrs later it is 12V and I got another suspension error (which I've cleared again). That's like 50% battery charge in 24 hours...which seems a lot for a 60mA draw. Could my alternator be causing issues? How can I accurately test that? (When I start the car the voltage goes up to 14.x)
Next step is to poke around in the rear fuse box. Just this moment realise I forgot to open and tape the front glove box latch Crying or Very sad so will do that after and wait another 30 mins!
No trackers/immobilisers connected that I'm aware of, but will have another look.
There was a dash cam connected which kept falling off the windscreen so I unplugged it and left the cable wrapped around the rear view mirror. Could that be causing a draw at all? No idea where the cable even connects to...! 2005 L322 4.4 AJV8
Post #680670 18th Dec 2023 5:53pm
pcourtney
I have just gone through all this myself earlier today, if the car is stationary for 2 or 3 weeks the battery is dead, but this is on my RR 2004 4.4 BMW Engine Petrol V8
On my MM (Multimeter) it reads 59 milliamps, so I too have a parasitic battery drain over all these years Sad
Post #680673 18th Dec 2023 6:02pm
Phoenix
Post #680677 18th Dec 2023 6:23pm
camcc
OK....after a few hours measuring across fuses I am unfortunately no closer to finding the source of my ~60mA drain.
Frustratingly my Owners Handbook has the wrong fuse diagrams (fuses don't correlate to what is actually plugged in). Diagrams I found on Google for 2002-2005 and 2006-2010 models are also wrong! Only what's printed in the car is correct.
Rear Fuse Box - there were no fuses which had a clear/solid reading, however the below showed a potentially phantom reading for a few seconds, so I removed them anyway and waited 30 minutes. Multimeter connected to the battery still showing 50mA draw!
F8 Heated rear window - Removed fuse
F13 Air suspension compressor - Removed fuse
F16 Central locking tailgate - Removed fuse
Front Fuse Box
F22 AV not sure what - Removed
F26 Windscreen wiper delay ECU - 0.8mV/493mA - Removed
F40 CD Changer - 0.3mV/20mA - Removed
F46 Instrument pack - 0.7mV/46mA
F47 Heated washer jet relay - 0.3mV/68mA - Removed
F49 Nav, On-board comp, monitor, Audio system - 0.7mV/158mA - Removed
Waited for 30 minutes and the multimeter connected to the battery still showing a 50mA draw!
Not sure where to go next!! Sad
Positive cable going through the bulk head
Positive cable going down the side of the engine
 2005 L322 4.4 AJV8
Post #680696 18th Dec 2023 10:20pm
camcc
Phoenix wrote:
The suspension error could be the cause of your battery drain if it is causing the system to be more active than it should - what error are you getting?
See pic below. It happens when the battery voltage gets down <12V. I think it's a result of the drain, not the cause but happy to be challenged on that. Also, see previous post above for latest troubleshooting update. Appreciate all your advice so far.
 2005 L322 4.4 AJV8
Post #680698 18th Dec 2023 10:30pm
Phoenix
Post #680699 18th Dec 2023 10:33pm
Phoenix
Post #680700 18th Dec 2023 10:35pm
camcc
Phoenix wrote:
What DTC are you getting for the suspension fault
Code is:
U2007-67 (AF) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event
. 2005 L322 4.4 AJV8
Post #680702 18th Dec 2023 10:43pm
Phoenix
Post #680705 18th Dec 2023 10:55pm
camcc
Eek, that is a bit above my current skill set!
I will need to do some research on how to check those bits (air line vent etc.) are they all under the dome in the middle of the spare wheel? I don’t have any water ingress/or damp in the boot.
New air suspension relay on order just incase. 2005 L322 4.4 AJV8
Post #680709 18th Dec 2023 11:42pm
Phoenix
Post #680718 19th Dec 2023 10:12am
Have you tried physically disconnecting the SatNav DVD unit yet? .
Post #680759 19th Dec 2023 6:09pm
camcc
Hi all,
Apologies for the radio silence. I've been away over Christmas and haven't had any time to troubleshoot my battery drain further. The good news is I disconnected the battery while I was away and she started up no issues after a week or so. I've driven her almost every day since so no further non-start issue or error codes (but I assume I still have a drain)
Since my last update I've replaced the air suspension relay and cleaned the contacts on the air suspension fuse. I've also got an air compressor vent/filter on order so will replace that as @Phoenix suggested.
@Joe90 I haven't yet unplugged the AV system and plan to do that next. I had watched something on YouTube which instructs to connect two optical cables together but need to have a root around in the AV cubby.
Side-note: Not sure why but all of Phoenix's posts on this thread have been replaced with '...' which is a little odd/unhelpful. Unsure if that is intentional or an automatic post expiration setting... anyhow! 2005 L322 4.4 AJV8
Post #681796 3rd Jan 2024 5:18pm
