![]() | Home > Technical (L322) > Westfalia drop out swan neck receiver insert removal |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
The entire assembly can be removed with the swan neck attached. It seizes up due to corrosion on the rear pin the square insert butts up to. I removed mine using a sledgehammer and a block of wood. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Lump hammer got mine out after a soak with plusgas. It's only the M16 bolt holding it + friction / rust. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
I had the same, as above, a big hammer and a block of decent wood, if it doesn't come out get a bigger hammer....
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
lots of wd 40 and careful tapping with a hammer ( as it used to say in the Haynes manuals) |
grizlyadams Member Since: 13 Dec 2023 Location: Gloucester Posts: 2 ![]() ![]() ![]() |
Believe me - there is A LOT of Bulldog BDX (better than WD40) on it already! 😁
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Have you tried a bit of heat, If you damage it I have a spare for sale |
