Home > Technical (L405) > Reduced Performance
comports
Reduced Performance
Evening all,
Out for a drive today, mainly motorway (and still enjoying the 4.4 SDV8’s ability pick up when i want to overtake) when, during a ‘spirited’ drive home after watching the F35’s and F15 at Lakenheath, when the dash lit up with “Reduced Performance” message and indeed had no guts under acceleration.
I thought for a minute that this could get expensive and pulled into a service station to check if there was anything obvious under come adrift under the bonnet.
Nothing to see so had to try to limp home and get it into a garage on Monday - only to find she fired up and was perfect, not a sign of any issues and back to full power.
I didn’t stretch her legs properly for the rest of the journey home but in general, was this another one of those “It’s a LandRover sir and totally normal” moments or should I get it checked out at the garage.
Will check later for error codes using IID but she drove totally normally for the last 50 odd miles.
Thanks as always Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #665770 2nd Jun 2023 8:12pm
caymanblack
United Kingdom 2017 Range Rover Autobiography SDV8 Carpathian Grey
Hasn't happened yet on my SDV8 but it did on a Sport I had .
It was fine after coming back to the car like you and it never happened again .
I wouldn't worry. overfinch modified
Post #665778 2nd Jun 2023 9:59pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Check the second turbo actuator isn’t sticking.
Post #665806 3rd Jun 2023 3:06pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
It was the fuel filter on mine . Changed and no further issues 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #665969 5th Jun 2023 6:11pm
PHG
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
It was the primary turbo actuator on mine. Tip listen for a strange noise after engine shut down to confirm. 2015 SDV8 AB
2008 TDV8 Vogue gone
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #679857 9th Dec 2023 9:20am
FANBELT2672
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi Newbie here,..... I've got a 2014 sdv8 vogue se that's chucking up high fuel pressure fault. I've looked up the ltb01083 bulletin and it looks like what's happening with mine. Question is has anyone done or seen a video of doing the repair loom?
Cheers
Post #679920 9th Dec 2023 10:21pm
