Home > Maintenance & Mods (L405) > fitting roof rails / ditch fillers
mkacala
United Kingdom 2019 Range Rover Autobiography TDV6 Carpathian Grey
hello , I have a L405 with panoramic sun roof. Planning a trip and need to get a roof box. So I have the rails and the OEM ditch fillers that fit over the brackets.
After the trip I will want to remover the rails....I think the car looks better without rails and I wont be using them again until the next trip !
My question is to all the guys that have fitted rails .... can the original ditch fillers be removed carefully enough so that they dont break / bend and are reusable ...the JLR instructions are to discard the ditch fillers ??!!
many thanks for your insight/comments
Post #679972 10th Dec 2023 12:30pm
Vogue
Done this - yes they can - no issues whatsoever 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #680001 10th Dec 2023 6:35pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Had rails fitted by the dealer and never taken them off, I actually like the look. Cross bars are fitted when needed. Given the ditch fillers are plastic, they are bound to break with regular removal/fitting, so I’d leave the rails in situ.
Post #680002 10th Dec 2023 6:39pm
mkacala
thankyou guys much appreciated.... are the ditch fillers plastic ? I thought they were aluminium (painted either silver of black ?)
Post #680019 10th Dec 2023 8:56pm
Phoenix
Post #680025 10th Dec 2023 9:39pm
mkacala
I'm not sure if they are noisy ... although I would guess the bars are noisy ? Well I have no choice so will fit the rails and bars and let everyone know how it works out !
Post #680030 10th Dec 2023 10:21pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Came here to write the same. I drilled mine as per the Powerful UK kit.
FWIW by the way, I wouldn't recommend the Powerful UK kit, it is poorly fitting, the plastic trims are very brittle and the supplied fixings are as soft as cheese. IMHO.
The only noise I got is because the right-hand rail doesn't fit flush enough with the roof. I've had to in-fill it slightly with some tap to stop it whistling. Once done, there is no additional noise from the rails themselves.
If I had my time again I'd stretch for OEM rails. FFRR SDV8 Autobiography
Post #680048 11th Dec 2023 9:49am
Andy S
No noise from the rails, even at motorway speeds. Put the cross bars on and there is a noticeable change in noise, but not excessively so.
Post #680099 12th Dec 2023 7:03am
