Home > Technical (L322) > Diesel leak from filter housing |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 |
Awhile back I had similar, diesel leaking from the bottom of the filter housing. So I dismantled the pipes, removed the filter with the housing, drained the diesel into a container and unscrewed the sensor.
10th Dec 2023 4:11pm |
Philclemo Member Since: 07 Feb 2022 Location: Lancashire Posts: 17 |
Thanks Tiprat. Yours was a 3.6, is the housing the same do you think? RR Westminster 2012 4.4 TDV8 Orkney Grey
11th Dec 2023 12:02am |
Update
4th Jan 2024 9:28am |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 143 |
Same thing here, filter not seated properly hence leak and I think it could be a problem caused by people not used to working on these vehicles. RR owner |
5th Jan 2024 1:18pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
And another similar tale that I also encountered with my local garage, I made it very clear to them what to do and FFS an "Oil Change" - I don't care what make and model the vehicle is, BASIC STUFF for a semi competant mechanic - but no you have to remind them what to do - crazy world we live in folks |
6th Jan 2024 7:39pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Name and shame the garage so nobody on here uses them as your first step Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Jan 2024 8:17am |
