Home > In Car Electronics (L322) > Replacing all Hartman kardon speakers
Tico
Costa Rica 2008 Range Rover Vogue TDV8 Tonga Green
I bought an L322 2008 2 years ago
All sound system is in very poor condition and is crackling
Is there a store where you can buy the whole kit to replace speakers , twitters , woofers aka the whole kit ?
Thanks !
Post #679595 6th Dec 2023 5:35am
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
you can buy the speakers direct from JLR at not too bad a price - just double check which system you have as there are different connections depending what system you have! https://parts.jaguarlandroverclassic.com 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679625 6th Dec 2023 4:44pm
IMHO the originals are not that well made, if I were you I'd source some locally.... Thumbs Up Pete
Post #679636 6th Dec 2023 5:34pm
p38arover
Australia
Look for Harman Kardon not Hartman Kardon. Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #679679 7th Dec 2023 12:26am
garyRR
It isn't too expensive to make a big difference, so you're in luck.
First thing is that the Land Rover (Alpine system I think) DSP isn't the best at segregating the levels. The speakers perform way way way better by using your own DSP amp or by replacing the head unit. I have stock speakers and changed my head unit to an Android one. On the android head unit, I can customise the levels at different frequencies and the sound system is so much clearer and now really packs a punch. In short, you can isolate which sounds are handled by which speaker to get the best out of the system. There is a vast improvement.
Second thing is that the low range speakers in this car are what let it down really. Some good quality low ranges mean you can reduce the reliance on bass levels and therefore bring through more clarity from the rest of the system. GAS PS3M62 PRO SPL are exact retrofits for the mid range speakers in the doors and are only slightly more expensive than the Land Rover (Harmon Kardon) ones. They're reportedly very good. These speakers can be changed without the need to remove the door card (you remove the screws and level open the bottom of the door card). 2015 Range Rover Autobiography 4.4 SDV8
Post #679713 7th Dec 2023 6:29pm
th3chainrule
United States
Another vote for changing out the factory speakers with aftermarket. FYI - The 2012 factory system uses 2 ohm speakers, not sure about the 2008, but be mindful of the impedance, especially if you are not going to add amplification.
I replaced mine with 2 way and 3-way component speakers from CDT Audio. I noticed a world of difference in clarity, especially on the low end after swapping mine out. I cant say I am a fan of the Logic 7 system at all, especially after swapping the speakers out, the music is so much clearer with Logic 7 disabled.
Post #681887 4th Jan 2024 11:40pm
