Home > Technical (L405) > Front Drop Links
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Front Drop Links
Hi I want to fit new front drop links to my 2013 SDV8 4.4 A/B with ACE system Is this an easy job or is there anything I should look out for especially with regard to the ACE system
Thanks
Post #678462 21st Nov 2023 9:35pm
Phoenix
It's no different to changing them on non-ACE vehicles, in fact, it's the same part number. Clean the threads as much as possible on the old ones, if they're badly corroded, run a nut on & off the exposed threads before you undo the fastener.
Post #678485 22nd Nov 2023 8:24am
