Home > Maintenance & Mods (L322) > New to the forum and I have a few questions... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8160 |
Nine times out of 10 PO430 is telling you the oxygen sensor has failed, not the cat... change it first...
7th Nov 2023 10:51am |
oliverw Member Since: 20 Oct 2023 Location: UK Posts: 2 |
Hello Pete and thank you for the very concise instructions. I'll give the WD40 a go.
7th Nov 2023 12:08pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3172 |
I'd get the suspension bushes inspected before you pay out for any alignment. Lemforder are good but avoid Britpart. Removing the ball joint can be very difficult and maybe best left to a garage. If they have never been changed it's likley both front upper and lower arms will need replacing. I wouldn't sprayWD40 anywhere near a belt. Spray water on it and if the noise goes away the belt is worn/contaminated and or the tensioner has gone weak (talcum powder can sometimes quieten it for a while). If the sound remains then you can pretty much assume it's a bearing on a pulley. 2012 TDV8 Vogue (L322) |
7th Nov 2023 3:27pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1372 |
Welcome Oliverw nice looking motor, hope you sort your issues. |
7th Nov 2023 3:57pm |
Do whatever Jaygee says, he knows far more than anyone else on here.... Pete
7th Nov 2023 5:01pm |
No need to that Pete. I had a squeaky belt for ages and tried everything inc WD40. Also had front and rear suspension arms replaced and wasted money on alignments instead of getting them replaced when they were obviously worn ( original) Just trying to save the OP some ££. Notice I didn't mention the fault code as only had CAT issues on non LR cars so my experience is not relevent. 2012 TDV8 Vogue (L322) |
7th Nov 2023 5:05pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Where in the UK are you? Lots of good and bad independent specialists about !
7th Nov 2023 9:10pm |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 |
Hi mate send me your reg, and i will price up any parts you might need. (I am in the trade) L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
8th Nov 2023 7:18am |
