Home > Maintenance & Mods (L405) > Block Heater Issue
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Block Heater Issue
I've just had my block heater wired up with the genuine wiring kit. Quite an elegant solution with a socket on the bumper (and cost a king's ransom).
I've just tested it and the earth leakage safety switch keeps popping off. It's rated at 1875 Watts.
https://www.amazon.ca/dp/B000KKLMCU?psc=1&...ct_details
Wondering if there could be short in the system? How would I test?
Suggestions welcome!
Post #676730 28th Oct 2023 6:28pm
Phoenix
Well there's a couple of options - the wiring diagram is, as expected, simple.
Check the electrical earth is connected to the vehicle ground.
Check there is no water / ice in the connector.
Test the disconnection device with a 'known good' device that draws a similar current - but not a double insulated one.
If all OK, then an insulation test will be required.
Post #676732 28th Oct 2023 6:43pm
Salsbury
Many thanks for the diagnostic suggestions.
Post #676733 28th Oct 2023 6:53pm
