Home > Technical (L322) > 2012 TDV8 4.4 Oil pump woes
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi
Had a leak from my oil pump ( typical front right lower engine block area - tray catches most of it before it gets on the drive ). Not excessive but got on the belts etc. Cars done just 72k so decided to get a new OE pump / gaskets fitted. Valley and rear remain dry .
friendly knowledgable LR main dealer tech explained that this is not uncommon and that some pump drive shafts move in an eliptical fashion ( the throw out is hardly measureable when cold) and after a while the leak will return if that's the underlying cause. New to me. He said that some LR dealers will do the job (£££££££££) but wont warranty it for three weeks / 500 miles. If it comes back inside those limits - no warranty.
Anyways I decided to get it done but by a local indy. Got an OE pump and other bits n belts . Within a few weeks, yes, ******* leak started again. Any ideas out there? But this time it seems more focussed and hasn't got on the belts .
Thanks
Ken ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #676705 28th Oct 2023 10:17am
