![]() | Home > Technical (L322) > 4.4 TDV8 oil smell question |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The smell may just be the old oil down in the V burning off - it takes a while but I'd expect it to be gone by 10,000 miles.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Oil pump gallery plugs can leak a bit of oil. Front of engine. Your specialist will know about that hopefully and have checked it over |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 ![]() ![]() ![]() |
Did you just have the oil cooler gaskets replaced or the whole the oil cooler? 2012 TDV8 Vogue (L322) |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 154 ![]() ![]() ![]() |
The previous owner just had the gaskets replaced rather than the actual oil cooler. He spent almost £2000 with the garage which left me puzzled as to why he didn’t replace the cooler.
Eek!
I should have been clearer. The £2000 bill included EGR gaskets, oil cooler gaskets, belts and tensioners and a service. The devious owner had complained of an oil smell. The bill also showed engine cleaned of all oil deposits and now no oil leaks.
That's a good price if it included all that inc the EGR cooler gaskets as these are a pig of a job - so good it may be too good to be true.....
I thought it seemed cheap having brushed up on lots of related old threads on here. I don’t have an endoscope but may buy one, is it a pig to remove the intake to access the V?
