Home > General (L405) > auto climate without a/c
planetkiller405
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
Hi, newbie to this forum. Question on climate control - if you have climate on, it switches on the a/c. If you then press off the a/c, the auto buttons go off. Does this mean climate has stopped running with auto because the a/c is off? (on my f31 bmw you can switch off a/c and auto stays on which is what I use - why - because i have dry eyes and the a/c irritates), Cheers for any help. L405 2014 SDV8 ATB
Post #676400 25th Oct 2023 10:19am
CS
That button switches the air con on and off altogether, i.e. not just the auto function. Only Range Rovers since 1988
Post #676402 25th Oct 2023 10:57am
Phoenix
Full auto climate requires the A/C to be switched on, I'd imagine that if you recovered the refrigerant then it would work on full auto without removing the moisture from the air. I would imagine that the rest of the system would continue to operate as if in 'auto' if the aircon was turned off, I've never tested that functionality though.
Post #676421 25th Oct 2023 2:12pm
planetkiller405
thanks, having noticed more about this while driving today, I think there is still some sort of auto function as the blowers are still on but there is no fan level showing on the dial - so I think it just carries on "auto" without a/c
Post #676493 26th Oct 2023 12:53pm
Martin2
The auto fan / temperature etc all works when the AC is switched off, same as your BMW. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #676508 26th Oct 2023 5:08pm
planetkiller405
Yeah thanks Martin2 that’s kinda what I realised today. Cheers
Post #676510 26th Oct 2023 6:14pm
