![]() | Home > General > Buying Question: Mileage Sweetspot |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
On your scenarios you’d pay more for the lower mileage and then have to pay again to get the “coming up” repair work done.
Ignore mileage and just go on condition as they are all very old now and a low mileage one that's just been driven round town will be in worse condition that a high miler that's done mostly M-way driving. 2012 TDV8 Vogue (L322) |
Baltic Blue’ Fault History Log thread….
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I’d go for higher mileage with a wad of receipts and invoices for work done. E.g oil coolers always need replacing. As do starter motors
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
bought mine on 83k, now on 124k. inlet manifold and oil coiler changed. just over a coupla grand for both. now running better than ever.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Afraid I dont know anything about diesels but I have a couple of l322 one with 120k the other 240k I have the gearbox oil changed every 30k the engine every between 6 and 10k no problems with either sure the 4.4 will do the same I just changed the rear bags on the 240k and when they were cut open there was still a lot of life in them the fronts I changed at 125k on one the other not yet. Front arms about every 30k rears go on for ever just replace all rear hub bushes at 240k but think I have done them before.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Not much else I can add to the above.
Unfortunately when you buy from a dealer you won't find loads of receipts for previous work as GDPR rules mean all personal info has to be removed from any documentation. No dealer is going to go through a folder of repair receipts with a pair of scissors and cut out all the names and addresses so you have to go on your own or a 3rd party inspection. Buying privately if the owner has had it a long time and GDPR rules don't apply. 2012 TDV8 Vogue (L322) |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 193 ![]() ![]() ![]() |
Mileage as has been stated, isn't a great indicator of the condition of a 12 year old car. How many owners, what was the car used for, how was it treated, was it regularly serviced etc.
Smell the Glove Member Since: 21 Oct 2023 Location: Derbyshire Posts: 17 ![]() ![]() |
Well if you're in Dronfield, I'm t'other end. Near Melbourne/Castle Donington. |
Ah, so you are.
Sadly it had been reserved with a deposit at the weekend. |
T4ls Member Since: 09 Sep 2023 Location: Berkshire Posts: 16 ![]() ![]() ![]() |
I was in a similar position to you a few weeks back, weighing up mileage, age cost etc. Missed a few that I wasn't quick enough on. What I found looking every day at Auto Trader, car guru etc is that one got a bit of a gut feel of which cars would go quickly and which would hang around for weeks which gave a good indication of whether it was a decent or a bad buy. I didn't focus too much on mileage in the end and just looked for a really good service record knowing that there would be a few £k needed for maintenance each year.
I just thought I’d leave a brief update as to my position on the search for an L322.
