Home > Technical (L322) > air suspension ecu |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2385 |
What leads you to consider that the ecu is faulty? It's probably the most reliable part of the air suspension system. |
19th Oct 2023 9:55am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Unless it's suffered water ingress? it will require height calibration as a minimum - possibly coding if the VIN from the donor vehicle is coded into it (it should be but can be a bit hit & miss as to whether it was done at build, the same goes for TPMS modules).
19th Oct 2023 11:33am |
I know of a still-faulty chassis module in a 9-month old Defender that has been faulty since new, although the fault is with the CVD not the ride height function of the module. LR tried to swap with one from a brand new vehicle but couldn't reprogram the borrowed module as new so that it would be accepted in the other vehicle. It solved the issue but created other issues so was removed. |
19th Oct 2023 11:44am |
It can be done with engineering access but JLR won't give out the codes for donor module substitution, there's a pretty good FOSS code generator written in Python, but it uses a command line interface so most dealer staff wouldn't have a clue.... |
19th Oct 2023 12:14pm |
The AU JLR technical people were in discussion with UK support for 3 days but still couldn't reset the module. LR offerred to replace the vehicle with a new one but the owner had invested quite a lot in accessories. The vehicle will be parked until a new module becomes available upon his return from his desert trip on non-softening CVDs. |
19th Oct 2023 12:25pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 289 |
hi all
19th Oct 2023 1:07pm |
That DTC suggests it's still in tight tolerance mode, I don't use IID but those E1 & E0 codes usually seem to mean the inputted measurements are out of valid range.
19th Oct 2023 2:58pm |
yea have tried several times on the flat to calibrate but when i open up guided calibrate it just comes up with error e1 or e0 ..............i have also clicked on normal tolerance's and comes back with operation complete or active (cant remember which now) .i will keep trying tho 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
19th Oct 2023 3:19pm |
All I'll add is that the only time I've seen that specific DTC is when calibration has failed and the suspension is left in tight tolerance or an inconsistent state, I've never had that happen with Autologic or SDD. Have you tried a battery disconnect to let everything 'calm down'? Also make sure you have the engine running for a good few minutes before calibration to ensure battery voltage is stable and high enough. |
19th Oct 2023 3:56pm |
yes that was my thinking ...ecu has got it self confused i will keep trying if not than it maybe a ecu swop as i cant driving it this way dont know what else i can do 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
19th Oct 2023 7:25pm |
TBH, it'd probably be best to book it into an indie with Autologic / SDD or a dealer and get them to do a suspension height calibration - it'll work out cost effective in the end. |
19th Oct 2023 7:44pm |
that may have to happen. Think i will drop gap an email and ask if they can do anything ?...dont ask you never know but ill keep trying at the mo 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
20th Oct 2023 10:29am |
