Home > Maintenance & Mods (L322) > help with part number, retaining clip for mechatronic sleeve
arishmawy
Honduras
Hello everybody
Can someone please help me identifying the part number of the retaining clip for the mechatronic sleeve on a 6speed ZF gearbox for a 2010 FFRR 3.6 TDV8.
Many thanks
Post #675894 19th Oct 2023 3:47pm
Dolphinboy
RRPhil is your man for gearboxes on here. do a search of his posts on here.
Hope all well with you Phil! ?
Post #675900 19th Oct 2023 5:03pm
Phoenix
Likely it'll be a ZF-only part, if available. It may be cheaper to get hold of a used/failed valve block and remove the part you need.
Post #675905 19th Oct 2023 6:16pm
Bingo_123
Did it get broken during removal ?
Post #675930 19th Oct 2023 10:06pm
