![]() | Home > Technical (L405) > Multiple Faults Codes possibly Autowatch Ghost related? |
Sounds more like a problem with a ground stud in the front wheelarch - the giveaway is one headlight not working, check that side first. |
bestman Member Since: 15 Jun 2018 Location: Hampshire Posts: 54 ![]() |
Thanks Phoenix, will try that. |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 403 ![]() ![]() ![]() |
100% earth stud if a light and speedo is out, whichever side the light is out it'll be that side earth stud. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Thanks 4RRS and Phoenix,
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1511 ![]() ![]() ![]() |
Definitely the ground stud I had exactly the same symptoms, fix the stud and problem solved and normal service resumes including the headlight
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
This is where the ground point is, front of the offside arch, there is one the other side as well with just 2 connections instead of the four here...
Thanks also to DrF and Haylands - amazingly helpful. |
Thanks All,
Thanks for confirming - a pity the garage in Ullapool couldn't do more than plug in & shrug shoulders, it's not exactly uncommon. |
