![]() | Home > In Car Electronics (L322) > New to RR - L322 ICE Gremlins |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Welcome.
faulknerm Member Since: 29 Sep 2023 Location: Warrington Posts: 6 ![]() ![]() ![]() |
Thanks. |
I never had one of those, my TD6 was earlier. I know yours uses a MOST fibre network for the communication bus and sometimes the Bluetooth modules fail. What I’m not sure of is if they offered Bluetooth if there was a factory fitted phone in the car, but others will know better.
The good old British weather isn’t giving me much chance to play today, however have checked and confirmed there’s a BT module, and it’s a Nokia as suspected.
Well that’ll be why the BT isn’t working! 🤦♂️
Looks like the unit went faulty and someone took it out the fibre loop and joined the fibre ends to keep the rest of the system working.
Apologies for the double post, my phone had a ‘moment’.
Cancel it and get the later one - better all round. It needs a small wiring alteration but is otherwise plug & play.
That’s the one I’ve ordered, found lots of mentions in past threads so took the advice. 😊 2005 L322 TD6 |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 704 ![]() ![]() ![]() |
Although, they're virtually no use & you've said it's not a priority, the Venturecam probably doesn't work due to knackered rechargeable batteries.
