![]() | Home > Technical (L322) > Door sensors and ECU switch-on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35609 ![]() ![]() |
from memory when you unlock the doors, the lights come on so they must be linked to the 'unlocking'
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
Lights can be disabled/enabled by press+hold the light switch ...it gives a flash and then they dont come on for unlock / door open.
you could put an inline switch from the battery so you can disable all the electrical systems.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
The door latch itself contains what tells the car the door is open I believe.
