Home > Technical (L322) > Battery drain |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3229 |
How long are you leaving the ignition on without the engine running before the fault comes up? 2012 TDV8 Vogue (L322) |
19th Sep 2023 5:18pm |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 55 |
Its as soon as I get in the car the message is there |
19th Sep 2023 5:24pm |
Hi Guys bumping this thread, just been sat in the house on my phone and realised no sound was coming from my phone and it was showing that it was connected to a Bluetooth device. When I checked it was connected to the invery in the car. Went out to check the car and it's locked but the radio was lit up showing the range rover logo and the orange blinking power light. Opened the car and locked it again and it all shut down. Has anyone else had this issue? Thinking this is what could be draining the battery if the radio is randomly staying on. |
24th Sep 2023 4:20pm |
I have the Invery BT audio adapter but it shuts down when the car is off but this will certainly be a battery drain if it's not shutting down. BTW my phone connects to the LR bluetooth handsfree and only audio goes through the Invery. 2012 TDV8 Vogue (L322) |
24th Sep 2023 6:36pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Faulty diode in your alternator? It's quite common on the 4.4 TDV8 as a cause of battery drain and spurious errors. 2015 Range Rover Autobiography 4.4 SDV8 |
24th Sep 2023 8:42pm |
Is there anyway to test this or is it just a case of replacing the alternator? |
24th Sep 2023 8:51pm |
I'll have to pass on that one.
24th Sep 2023 9:02pm |
Easier just to replace the whole alternator as the difficulty involved in removing the fan and shroud etc to get to it mean you may as well. As you have a BT adapter that is not shutting down then this would suggest the first thing to investigate - simply unplug it for the time being. 2012 TDV8 Vogue (L322) |
25th Sep 2023 6:58am |
Super Sloth Member Since: 23 Jun 2020 Location: Derbyshire Posts: 25 |
These cars can behave strangely with anything but a perfect battery. Budget to renew every 3-5 years.
1st Oct 2023 7:26pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Could be barking up the wrong tree here, and I'm sure people who know can confirm/deny this. When you replaced the battery, did you tell the RR it had a new one? I used the IID tool.
1st Oct 2023 10:37pm |
Good point on resetting the BMS via the GAP tool. 2012 TDV8 Vogue (L322) |
2nd Oct 2023 8:49am |
