Home > Technical (L405) > Rear Traffic and Blind Spot Monitors
Philip
Can anyone confirm that both these systems use the same rectangular sensors in the sides of the rear bumper?
Post #673308 13th Sep 2023 7:06pm
Kot
Fill your profile in. 2018 SE SDV8 4.4 Byron Blue
Post #673310 13th Sep 2023 7:32pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Re: Rear Traffic and Blind Spot Monitors
Correct same sensors, just coding. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #673311 13th Sep 2023 7:44pm
Philip
Thanks - after a minor knock to back bumper, I have error messages saying both systems are unavailable (and a permanent orange dot in both mirrors). There’s a bit of a mark on the back of the nearside rear bumper sensor, so I’m assuming that’s the cause.
Post #673316 13th Sep 2023 8:24pm
4RRS
Ideally you want to check for fault codes to see whether it's an internal fault with the radar unit or alignment as I seem to recall the fixings and bracketry are quite fragile.
Hope this helps L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #673318 13th Sep 2023 8:35pm
Philip
Thanks. Basic scan just identifies the fault (apparently), but not the specific sensor or location. I’ll have to find somewhere with diagnostics, I expect.
Post #673320 13th Sep 2023 9:05pm
Phoenix
Get it up on a ramp, chances are the RADAR is out of it's bracket and needs re-fitting, if you're lucky it'll re-calibrate itself, if not, there are many non-dealer options for recalibration.
Post #673322 13th Sep 2023 9:33pm
4RRS
The code to look for is U3000-78, Control Module - Alignment or adjustment incorrect, any other code is comms faults or internal failure.
If as above you will need to :- If the DTC is cleared, a test drive of at least 40 minutes duration is required in order to confirm that the fault is rectified (the DTC will not set again prior to this interval).
If it doesn't reset, then its time for a replacement, as Phoenix said, check it is securely mounted.
Good luck! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #673334 14th Sep 2023 9:45am
Philip
Thanks both, very helpful - the maybe-damaged unit has been off and swapped to the other side - still the same symptoms. I’ll check the error code.
Post #673370 14th Sep 2023 7:18pm
Philip
Does anyone know if these sensors need coding to the car (ie will a used one plug in and just work, assuming codes cleared)?
Post #675037 7th Oct 2023 10:42am
Phoenix
It depends, if it's a used one, it'll need coding - if it's new, it will have the VIN & config pushed to it - both will need calibration though.
Post #675038 7th Oct 2023 10:55am
Philip
Thanks.
Post #675053 7th Oct 2023 2:07pm
SPOOKS
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
I also have this problem. I took mine to an indie this morning (l405 2015 AB ) and turns out the right hand bumper camera has a hairline crack so in turn had the blind spot and rear traffic msg. So I would suggest checking all cameras are ok. My cameras are all working apart from the crack. Now waiting to see if the garage I bought it from are going to take care of the bill . ( £789.00 ) 😳
Post #675165 9th Oct 2023 5:06pm
Phoenix
I don't see how, the front bumper cameras are not used by the blind spot monitoring - they face the wrong way for a start.
Post #675174 9th Oct 2023 5:32pm
SPOOKS
Apparently they used a scan diagnostic and it came up with right hand front module which they said was the camara . They also said they have done one once before. This is a Land Rover specialist indie with excellent reputation. So I can only go by what I was told. If I get the go ahead for them to fix it I will keep you all posted .
Post #675185 9th Oct 2023 6:45pm
