![]() | Home > In Car Electronics (L322) > rear camera in a 2005 range rover hse |
marbleweazel Member Since: 20 Jul 2011 Location: Sacramento, CA Posts: 13 ![]() ![]() ![]() |
Is it possible to activate the rear camera input on the touch screen? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
you need to switch it on in the CCF [car configuration file]..apparently dealers cant do it but autologic and faulmate can..
found a local shop that has autologic......said he hasnt done it before. I am in the US and have the naviagation accept screen and no destination input while in motion. Can this also be fixed with the autologic? |
afaik you cant do anything about the 'acceptance' screen but the destination in motion can be done by a dealer so autologic should be able as well... |
do i need any modules for the rear camera or just the camera and the autologic to activate it? |
no modules just a 'smb ?' connector to go into the back of the screen and the camera/cable and of course the activation.... |
okay got the camera installed in one of the rear lic plate lights. New question is there some type of resistor that i can place between the wires so i dont get the "check lic. plate light" nag? |
you can get a resister of ebay or wire in a bulb......i gather the camera bulb is a led then.. |
Well i removed the whole bulb assembely to make room for the camera. The camera doesnt have a light in it. Was hoping some knew the exact type of resister to put between the wires. Dont like the idea of a bulb in there because of the heat and possiblity of melting the wires. |
.something like this will do the job http://www.ebay.co.uk/itm/2-Pcs-Gold-Tone-...5d2fa94ace |
ordered! thanks for the help |
tolley Member Since: 29 Aug 2011 Location: gloucester Posts: 99 ![]() |
https://vision-uk.co.uk/productPage.php?productId=145
need to measure up and confirm this will fit..as said on another thread the ad says its for a sport.... |
