![]() | Home > In Car Electronics (L322) > Can bus faults |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Is this maybe being over-thought?
Diditg Member Since: 14 Sep 2021 Location: Durham Posts: 8 ![]() |
Hi Garry,
Have you checked the fuel pump for the FBH is functioning correctly?
Hi again Garry,
Have you followed the re-learn procedure for the remote and also replaced the battery? The remote needs a very specific 3.0V to operate.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
As Gary says if everything is working, apart from a minor FBH issue, then it's pointing towards your reader... most on here use the Gap IID tool, or take it to an Indie and get them to see if they can talk to all the ECU's.... |
Hi Garry, Yes, tried all of that. Remote is working and paired to receiver. And the HEVAC hears it. I can even see the initialisation signal over the bus Remote will operate the system but when I use the remote it does everything, initialises the heater pre ignition sequence, but then cuts out as though the ecu in the fbh wasn’t seeing the ignition, ( ie incorrect resistance in the glow plug) or the voltage is to low. When I use the head unit to initialise the fbh, it operates as it should, initialises and then runs producing heat and warms the cabin. This is whether the engine is running or not. So I don’t suspect it’s a battery voltage thing. |
Hi Garry, Yes, probably the next step, but thought it prudent to check out the busses first, I suspect a low voltage on either can high or low of the medium speed bus, as I’ve seen it reported that this might not actually throw a fault if it’s on one one or the other of the legs. I’me fairly certain that the voltages on the High speed bus are ok but I think the voltage on can Low of the Medium speed bus ( actually Low speed bus) is lower than I’d expect, if I could verify this then at least then I’d be know to look for either a dodgy splice or corroded connector. |
Just so there's not confusion, I mean the battery in the FBH remote, not the car battery.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Temperature at which FBH provides heat to the cabin will be in your handbook
