Home > Maintenance & Mods (L322) > Well, we went on holiday, the FF didn’t like it….
JayGee
If cost were no object I wouldn't get an L405 that's for sure. 2012 TDV8 Vogue (L322)
Post #672627 3rd Sep 2023 11:03am
GraemeS
Haylands wrote:
Sounds like both turbos, both EGR's, both cylinder head gaskets, the gearbox and rear axle to me.... Whistle
Can't be both EGRs so there must be something else to add to the list.
Post #672628 3rd Sep 2023 11:29am
mjdronfield
Back from holiday. Moved car… no fault messages. Drove fine.
Booked into garage Wednesday for them to have a look.
Might be something simple….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #673039 9th Sep 2023 3:48pm
supershuttle
I struggled with restricted performance off and on for a few months. Indy fixed it by cleaning the MAF sensor, I didn't mention to them that I had already tried it (because I probably Censored it up) Geoff
Post #673042 9th Sep 2023 4:54pm
Flashman
I have had the water in fuel yellow restricted performance triangle come up a few times that often disappears on its own and is a common issue with the water in fuel sensor. But after sitting for a month due to waiting for rear brake lines to be fixed, when I picked it up, the yellow sensor came on and after filling with fuel it then came on with a red triangle that actually restricted the performance and limited the revs and speed.
Stopped, turned off engine for 15 mins, then started it up and all ok again with no red or yellow warning. Not had the yellow warning for two weeks now it is in regular use.
I think sometimes the system can get confused and over protective.
Touching wood right now, but it seems to have sorted itself out for now, so not that worried. Tom
Current Drive
Previous Drives
Post #673044 9th Sep 2023 6:06pm
mjdronfield
Car is at the specialist, not seen the message since and it’s still driving fine.
Their tech has read the codes and says there are a few but there is one relating to the oxygen sensor, so that would be their first port of call. Said the sensor is about £250 odd and with labour prob above £400 fitted. No issues seen with any rubber hoses/connections.
I said I’m a little reluctant to throw money at it if they don’t know it’s the actual fault, so we decided to clear the codes and id run it and see if it comes up again, then take from there as the codes would be “new” and more pertinent.
So I’ve told them to hang onto it and give it a big service and change the coolant, as that’s not been changed for a bit.
Should be able to collect it tomorrow and see how it goes.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #673283 13th Sep 2023 2:45pm
JayGee
https://www.fullfatrr.com/forum/topic67778.html Wink 2012 TDV8 Vogue (L322)
Post #673284 13th Sep 2023 2:50pm
DrRob
Check the pending codes too in your GAP. Sometimes points to an issue Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #673306 13th Sep 2023 5:44pm
mjdronfield
How many oxygen sensors does the 4.4 TDV8 have? Anyone know?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #673424 15th Sep 2023 1:50pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
just load it up again and make it think that you're going on holyday again...might trigger the isue.. Mr. Green
I think it has 4 oxygen sensors
this you tube (although for another year as yours) might give you an indication..
good luck
Post #673426 15th Sep 2023 2:10pm
mjdronfield
Rolling with laughter I dare say it would 🤣. It’s bound to do it again, prob as the MOT man is looking at it…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #673448 15th Sep 2023 6:04pm
