Home > Technical (L322) > Rear LED lights cracked !
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, have a 2010 and noticed earlier that both rear LED lights looked cracked as if they’ve been hit in the centre and cracked out over lime a spiders web. The black inner parts that are next the to boot seem like they’ve been hit as well. Just wondering if this is common for them to crack like this, seems strange that both are the same though. The bumper is unmarked so don’t think anything has reversed into the car when parked, would have had to have been something like a wagon with a high bumper.
Post #672451 31st Aug 2023 8:49pm
garyRR
Any signs of interference, aka someone trying to undo the catches on the lower tailgate who may have been levering against the lights, causing them to crack?
You can buy new lenses for around £45 each. Not cheap but considerably less expensive than replacing the light units. 2015 Range Rover Autobiography 4.4 SDV8
Post #672454 31st Aug 2023 9:14pm
tj196443
Never thought of that but upon checking there’s no damage to the lower tailgate or just inside the trim. It was in a garage a few weeks ago which let me down by not actually doing the work on the brakes, got loads of excuses but no work. I’m wondering now if they’ve swapped my good lenses for someone’s damaged ones. Wouldn’t be able to prove it though so stuck with them.
Post #672511 1st Sep 2023 6:49pm
tj196443
Post #672512 1st Sep 2023 6:50pm
JCW
Spotted these on eBay - maybe worth watching / bidding (nothing to do with me).
https://www.ebay.co.uk/itm/256203833208?ha...R8z_mKHKYg Jonathan
2007 Defender 90 XS Hardtop
Post #672513 1st Sep 2023 7:50pm
tj196443
Thanks JCW will probably go for the ones off the Supercharged as I’d like to keep it original. Got up this morning and someone had thrown what looks like milk or cream up the side of it so thinking it may be a disgruntled neighbour or something.
Post #672548 2nd Sep 2023 10:55am
garyRR
Time to get some CCTV and make sure you're not parked even remotely inconsiderately. 2015 Range Rover Autobiography 4.4 SDV8
Post #672608 3rd Sep 2023 8:38am
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
I have also experienced cracking rear lights and have an idea what causes it.
There is a breather and filter at the back of the light unit mine were completely blocked.
If the breather is blocked then temperature changes cause pressure or vacuum in the light unit something has to give which is either one of the seams split and you get water ingress or the lens cracks.
As a preventative measure I would either poke a hole in the filter or if you are keen remove the tissue filter paper and glue a new one in.
Post #672952 8th Sep 2023 10:13am
JayGee
One of mine mists up so will look at the breathers - never knew they existed so thanks Thumbs Up 2012 TDV8 Vogue (L322)
Post #672953 8th Sep 2023 10:33am
PeteT80
Nor me. I’m off out to check mine right now. That’s why I love this forum.
Post #672958 8th Sep 2023 10:54am
garyRR
Nor me, I shall also be checking 2015 Range Rover Autobiography 4.4 SDV8
Post #672965 8th Sep 2023 11:14am
PeteT80
They all seem to look ok.
Post #672972 8th Sep 2023 11:48am
tj196443
Took JCW advice and won the supercharge lights off eBay, interesting about the breather holes though had never thought of that as a culprit I must say.
Post #673048 9th Sep 2023 7:59pm
