![]() | Home > Technical (L460) > Range Rover Dashcam |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 279 ![]() ![]() |
I don't have one but had a loaner 110 with it the other week. Does yours beep when you hit speed bumps? I was thinking about it but the beeping would drive me mad |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35658 ![]() ![]() |
is this the one you have?
dc44back Member Since: 08 Feb 2023 Location: Surrey Posts: 28 ![]() ![]() |
Yeah. That’s the one. Have managed to see this. Doesn’t cover receiving notifications if the vehicle is approached when parked which is what I thought would be the case. Evidentially I don’t think this is a feature offered which defeats the object of having the camera for me. Having said that I guess it’s good to record journeys just in case of an accident. Unless of course it’s my fault 🤣🤣🤣
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
When you're parked up it goes into "parking mode" which means it records what it sees once movement is detected and triggers it. All recordings are saved onto the internal flash card. You can download any that you want into the app on your phone. I don't know any way of getting it to alert you in real time. Mike - MPx
That’s good but I guess you can only access the recordings when you return to the car and reconnect your phone to the camera via wifi - the down side to this is that if your car is stolen, you’ll never know that someone approached the vehicle 🙄 |
Crocs Member Since: 29 Jan 2022 Location: Ayrshire Posts: 109 ![]() ![]() |
Trust me. If your car is stolen, someone approached your vehicle. |
Fair point 🤣 |
...or if you'd got Craig to fit it for you he'd have done it properly and put the rear at the bottom of the rear window where you dont see it at all. Takes more effort of course but we like it to be right don't we... Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
calicoj Member Since: 18 Dec 2022 Location: Valencia Posts: 41 ![]() ![]() |
True, although in all fairness, this only happens when it's poorly installed. When properly placed, it doesn't obstruct your view. |
Okay, first off, the camera comes with a manual on how to connect to it and use it. Ask your dealer for it if he didn't leave it for you in the car. Alternatively, you can download it from the LR website. Secondly, the camera doesn't connect to the car's internal comms network, so it can't communicate with you when you're not in the car. This sucks balls, but that's the way it works, sadly. |
This is correct, but you can adjust the sensitivity level (to shocks) using the app. Otherwise, with the standard settings, it beeps when going over big or steep speed bumps, but definitely not each one. |
Haven’t been over any bumps yet so will test.
“When properly placed, it doesn't obstruct your view.”
That's where mine is fitted as well. |
