![]() | Home > Technical (L405) > Many issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
i would get that battery properly checked out..it could be the cause of your problems .. ... - .- -.
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 85 ![]() ![]() ![]() |
Thanks Stan 2019 Autobiography SDV8 Byron blue/black - current
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3196 ![]() ![]() |
there is a second battery in 405s isn't there? I had a second battery in my 322 and it drained the main battery causing totally engine stop etc. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
The 405 has a BMS system that keeps the two batteries separate until needed, apparently one flat one can't pull the other down but that's in theory...!!
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1583 ![]() ![]() ![]() |
@madasmad:
Just an update -
Did you check battery SOH, as Stan advised?
Thanks Gremlin |
So, after 10 days at LR Stafford - who have been great - they have fixed the following:
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 500 ![]() ![]() ![]() |
DDo these have to be used on the battery terminals or can they be used as effectively on the under bonnet posts? First time FFRR owner |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
Bloody hell mad who is the crappy dealer you bought that from, disgraceful. overfinch modified |
Hi madasmad,
It will (among many other things) tell you battery % remaining SOH (state of health) compared to new (not just SOC state of charge) -mine was a pitiful 29% last year before I replaced it, even though the car was still starting OK, -probably due to being plugged into a CTEK most of the time. It only takes a few minutes to complete a scan. If you end up needing a new battery, Tayna are very good, I got one of their own “Enduroline” AGM ones which came with a 5-year guarantee at a good price and fast delivery. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
