Home > Maintenance & Mods (L322) > Transfer case leaking.
The-Badger
Good afternoon all, I have a leak on my transfer case, on the output flange to the front.. does the transfer box need dropping to replace the seal…. I have been told the seal is on the inside of the box?.. it’s a 2007 TDV8. Many thanks in advance, Marc.
Post #672068 26th Aug 2023 5:31pm
RRPhil
Marc,
The front output flange has to be released from inside the casing for removal, before you can get at the seal, so I’m afraid that the transfer box will have to come out and be split. It was possible to replace the seal in-situ with the earlier NV225 transfer box used on the 5-speeds (because the output flange was retained with a nut), but not with the later DD295 unit. The procedure for your DD295 is covered in the Workshop Manual, though.
Phil
Post #672096 27th Aug 2023 10:42am
The-Badger
Hi Phil, thanks for confirming, much appreciated Sir.
Post #672100 27th Aug 2023 12:29pm
