Home > Maintenance & Mods (L322) > front end suspension knock
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
get the odd knock now and then from the front end thinking of a refresh would this cover all parts or is there additional parts needed
https://www.advancedfactors.co.uk/kit635o-...4704-p.asp 2008 Range Rover 3.6 TDV8 Vogue SE
Post #671960 25th Aug 2023 5:11am
DrRob
Don't forget the discount code too!
AF4LRP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #671962 25th Aug 2023 7:05am
garyRR
The OEM arm and ball joints are Lemforder, if that's what you'd prefer to fit Thumbs Up
I had to admit defeat and the car into a garage. They had to remove the wheel, disc, caliper and splash guard in order to get a nut gun on the nut to the arm, and they had to remove the driveshaft and entire knuckle in order to drill out the cassette ball joint screws. 2015 Range Rover Autobiography 4.4 SDV8
Post #671963 25th Aug 2023 7:32am
