Like most things; the testers are human and effected by things like a bad night's sleep, a crap boss, being hungry, off with life, or not getting any. I'm lucky that my mate does all mine and as he knows I keep a tight ship, is pretty chilled. We've talked before about this and he will sometimes be more lenient than others depending on the owner. If he knows they will not touch the car between MOT's then what might have been advisory items to another owner are fails, just so they get fixed. With others he knows they will get it fixed asap so passes them. This is for borderline stuff. Obviously a dangerous fail gets failed straight off. Some are chilled, some are little hitlers who love the feeling of power they hold, and others are corrupt.
Don't dismiss Halfords if you know your rules, if you know your tyres and breaks are in good nick you'll generally find that these guys don't have the desire to do other stuff and so unless it's very dodgy they'll let it pass. Not always, but it pays to know your brake and tyre limits. Obviously this only counts if you're happy to dive in and check stuff yourself but I've had arguments with testers before where I've prepped friend's cars for testing and then a hitler has failed it for something that is absolutely fine. One even tried to fail on cut tyres that I knew were fine. At the time I was near the garage and nipped round and asked him to point them out to me. Funnily enough he said he 'must have made a mistake'. Another time I had a friend be told that the brakes and suspension was trailed out of their fairly new to them car at the MOT (at Kwik Fit), despite the discs and pads being replaced by the previous owner, and the dampers having been replaced the previous month by me. It's as much down to the tester as it is the garage. I'd actually suggest a busy garage in the current climate as they're more likely to be lenient given how stretched they are. A quiet one will likely both be quiet for a reason, and also keener for the work.
