[sold] L322 3.6 TDV8 Autobiography | |
I have my 2009 Autobiography up for sale. I have had it for 2.5 years and covered approx 28k miles Santorini Black with Dark Grey Semi Analine leather. This has the extended leather package to include the upper and lower dash, all door cards etc. Piano black insterts in the dash. Thick leather bound carpets. Garage door opener and IPod interface. Two keys, one just having been restored to like new. Special order Autobiography diamond cut wheels
Comes with a full service history, mostly independents but the earlier stuff is LR. I have receipts for all the work I have or have had done.
This is a dedicated Autobiography edition with the normal vogue SE options It has the later style seats
Since I have had it, both egrs have been changed (receipt available), front and rear pad discs, hand brake shoes, front and rear, all the diff fluids and the transfer box. The gearbox has had a megaflush by local specialist MID Engineering. The rear subframe has been replaced (again by MID) together with the bushes, brake pipes etc. Rear suspension knuckles. Just replaced the top intercooler hoses as they were starting to look perished.
Mileage is 178000 and will edge up as I do use it most days
The rear arches and sills have been cut back, re welded (sill section) and then repainted. There is some corrosion to the tailgate but just bubbles under the paint at this stage
The peltier unit in the drivers seat has been replaced and both seats heat and cool as they should.
Everything works with no issues at all.
I have added a tow bar but only use it to tow a small trailer
I am based in Oxfordshire
Looking for around £5500
 | Click image to enlarge |
