Home > In Car Electronics (L405) > Just got a 2017 RR and I am having a technical issues! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1253 |
Regarding your oil level, did you remember to have the bonnet up? |
19th Aug 2023 1:05pm |
DamianK Member Since: 04 Aug 2023 Location: West Sussex Posts: 58 |
Errrrr tell me more! |
19th Aug 2023 1:29pm |
I've got the L322 but I presume it's the same method. Make sure the oil is warm. You have to have the bonnet fully open for the readout to work. You should wait at least 10 minutes for the oil to settle before checking or it won't work. You can press the cruise control cancel button twice if the reading is not available for a rough idea of the level. |
19th Aug 2023 1:52pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 598 |
The map update is a right PITA. Its done through here.com. You do need a subscription. You also need a 64Gb usb stick (Europe map size is around 34gb so won't fit on a 32). Getting it to download on your PC to the USB can take some coaxing but it should eventually do it. Once its on the USB stick, put the stick in the USB slot in the front arm rest cubby and the Nav screen will prompt to see if you want it updated. You'll need the engine running and about 30 mins, so do it on a journey when you know the route and dont need the map! You should get prompted that a new map is available about monthly, but not usually worth the pfaff - I just do it a couple of times a year. Service info only pops up on mine relatively shortly before it due - maybe a month before. Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
19th Aug 2023 2:25pm |
I cannot find where to take out the subscription - when I put my VIN in it just takes me to a page saying I have a connected car and to log into that.
19th Aug 2023 2:36pm |
Try starting from https://www.landrover.co.uk/ownership/inco...dates.html
19th Aug 2023 2:55pm |
When I go there and try and add my car using the VIN it never seems to remember and I just get sent to this page.
19th Aug 2023 3:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
pretty sure the HERE maps are only up 2020 so you might use those funds towards an android/carplay unit.. ... - .- -.
19th Aug 2023 4:25pm |
Really? They only supported the car for 3 years for map updates???
19th Aug 2023 4:35pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1551 |
@Stan, no that’s not right.
19th Aug 2023 5:57pm |
OP Read this thread:
19th Aug 2023 6:10pm |
And this one:
19th Aug 2023 6:14pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1248 |
Not true I update my here map each month 2018 SE SDV8 4.4 Byron Blue |
19th Aug 2023 7:16pm |
So the issue I seem to be having is I just cannot get my profile for maps to accept my car, I put in the VIN confirm the car and then it just doesn’t stick to my account. It’s really infuriating. |
19th Aug 2023 7:35pm |
