Home > Technical (L405) > Advice for Hot Weather Power Loss in Range Rover SDV8 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
Does your vehicle require the battery monitor to be reset when a new battery is fitted? If the battery monitor thinks that the battery is original then it will keep the charge rate lower than for a new battery.
15th Aug 2023 10:40am |
lee.norg Member Since: 23 Aug 2022 Location: Manchester Posts: 15 |
Hi Graeme, Thanks for your reply. Yes, I reset the BMS when the new batteries were installed. In the hot weather, the alternator still seems to be putting out between 13.7 - 14.2 volts, so it just seems very odd and frustrating at the moment that this only happens in hot weather. 2016 Range Rover L405 4.4 SDV8 Autobiography |
15th Aug 2023 10:46am |
As battery charge rate is reduced in hot weather to protect the batteries, perhaps the particular temperature sensor is faulty. If you have a diagnostic tool then maybe see if you can find a temperature sensor related to the BMS or charging to monitor. |
15th Aug 2023 10:58am |
It ended up being the BMS that would simply stop working and communicating with the ECM to send through signals to charge to the alternator in hot weather following diagnostics, so a new one has been ordered which will hopefully solve the issue (Fingers crossed). Thats what has been explained to me anyway 2016 Range Rover L405 4.4 SDV8 Autobiography |
23rd Aug 2023 12:28pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1195 |
Could it be that in hot weather you are using the AC, maybe a fault on that system? 2018 SE SDV8 4.4 Byron Blue |
23rd Aug 2023 1:24pm |
Thanks Kot, I'm going to give the new BMS a try and see if that provides resolution and then if not, you have a point over the aircon 2016 Range Rover L405 4.4 SDV8 Autobiography |
23rd Aug 2023 2:27pm |
Waylander11 Member Since: 06 Nov 2019 Location: Leicestershire Posts: 19 |
My sister has pretty much been having the same problem as you have described ,numerous times in the garage until finally they tracked down in the hot weather a faulty earth strap a new one fitted and touch wood has been fine for the last 3 weeks
23rd Aug 2023 8:56pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1386 |
I was going to say check earthing straps |
23rd Aug 2023 10:03pm |
You guys were indeed correct. After checking the earth on the negative battery lead and also the driver's side wheel well, the nut had snapped off the earth connection meaning the earth on the negative lead was loose and not touching the chassis correctly hence i think my intermittent issues in the heat. Thanks for all the help and advice that was very much appreciated and also went against the professional advice i had over the BMS. 2016 Range Rover L405 4.4 SDV8 Autobiography |
29th Aug 2023 12:58pm |
Glad it was of help and hopefully sorts your issuses out |
29th Aug 2023 3:39pm |
