Home > My Range Rover > Engine Failure 4.4 SDV8
Page 2 of 3 <123>
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
Well, I've got the car back on the drive and gave it a good clean and chucked it on ebay.
https://www.ebay.co.uk/itm/266365321473
I don't think I'm unreasonable in my price given someone with experience could swap the engine and still end up with a car a few quid cheaper. 2013 FFRR Vogue SE
Post #670848 9th Aug 2023 5:52pm
caymanblack
Good luck with the sale Martyn.
They look good in Green, Rare too. overfinch modified
Post #670849 9th Aug 2023 6:07pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Good luck, what a shame as such a lovely car
Post #670853 9th Aug 2023 7:20pm
ott
Estonia 2018 Range Rover Autobiography SDV8 Aruba
SDV8 in my 2018 AB failed after only 40 k. miles. All services done as required. Don’t know what caused the damage, symptoms were knocking noise and metal shavings in the oil.
Post #670924 10th Aug 2023 8:38pm
Kot
May guess is its oil dilution, turbo's spin at a very high speed, they need the correct oil wedge and dilution is not a Turbo's friend.
Would be interesting to compare failure rates compared with pre DPF engines.
Some owners it seems, just change the oil once per year.
And didn't JLR change the software on SDV8 so oil service command (dilution) was changed from 7% to 10% dilution, thats almost a 50% change on the previous limit!!!! Of course done to try and reduce complaints of customers receiving frequent oil service commands? 2018 SE SDV8 4.4 Byron Blue
Post #670929 10th Aug 2023 9:38pm
Martyn
The oil was changed on my car literally the week before so I doubt it was oil dilution in this case unless I had a dodgy injector or something. 2013 FFRR Vogue SE
Post #670931 10th Aug 2023 9:39pm
Oil dilution is more so on the AdBlue cars 16.5MY> Thumbs Up
Post #670945 11th Aug 2023 2:08am
memzy88
Whats the fault with it Martyn? Hole in the block as you expected or something else? 2020 Range Rover D350 AB
2017 Range Rover SDV6 AB - Sold
2021 Aston Martin DBS Superleggera
2017 Aston Martin DB11 V12 - Sold
2021 Tesla Model 3 Long Range - Sold
2014 Range Rover SDV8 - Sold
2014 Bentley Continental GT Speed - Onyx Black - Sold
Post #670949 11th Aug 2023 8:08am
Martyn
I don’t know unfortunately, I don’t have the time or the inclination to dig any further. 2013 FFRR Vogue SE
Post #670950 11th Aug 2023 8:12am
Kot
Interesting, I wonder why? the Engine Exhaust architecture is surely the same? 2018 SE SDV8 4.4 Byron Blue
Post #670951 11th Aug 2023 8:21am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
If you're interested you could try QP Online. they are a specialist for land rover rebuilds and do all the work inhouse.
They are based in the south east. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #670952 11th Aug 2023 8:22am
Martyn
So, hopefully the vehicle is now sold, I'm just waiting for the buyer to get in touch.
Whilst removing my bits and pieces from the vehicle I plugged my IID tool in and read the codes, the only code logged for the engine was the below:
PCM-Engine TDV8
P0235-17 (2Cool Turbocharger/supercharger boost sensor A circuit - General electrical failure - circuit voltage above threshold
( on 06-08-2023 10:39:57 at 82227 mi ) 2013 FFRR Vogue SE
Post #671174 14th Aug 2023 4:30pm
JayGee
Turbo overspeeding causing power spike? 2012 TDV8 Vogue (L322)
Post #671177 14th Aug 2023 5:21pm
Martyn
I'm not sure why this was moved to 'My Range Rover' but either way I thought I'd follow up on what was found by the new keeper.
- There was a pretty decent sized hole in the sump caused by a failed conrod.
- The gudgeon pin for the failed conrod was trying escape.
- The block was cracked.
- Both intercooler hoses had alot of oil in them.
It's certainly looking like turbo failure then lead to oil being fed into the inlets which then caused the engine to be hydrolocked?
The new keeper will be popping in a new engine along with a pair of turbos a few other bits, but at least it'll live on! 2013 FFRR Vogue SE
Post #671725 22nd Aug 2023 8:53am
Very interesting, thanks for updating. What have you bought to replace it..?? Pete
Post #671726 22nd Aug 2023 8:57am
Page 2 of 3 <123>
