Home > Technical (L322) > Adaptive dynamic fault/wiped ecu L322
Bennyis01
England 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Evening all
Would like to pick your brains with an ongoing issue, I keep getting an adaptive dynamic fault which when travelling at more than 40/50mph vehicle goes into limp mode. All the special features are disabled i.e. Snow mode,off-road driving 4x4 diff lock etc etc.
I've been told by garage that Ecu has been wiped , how I don't know, I'm told it the height controller ecu can this be re flashed and has anyone a rough price if possible please.
Many thanks in advance
Jason
Post #669669 23rd Jul 2023 9:08pm
mjdronfield
Never heard of that before. I’m assuming it’s still possible to read the error codes?
Normally it’s the known issue of a wire breaking on top of the front shocker strut, as they turn with the wheels and get brittle with age. That causes an error all the time though….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #669670 23rd Jul 2023 9:41pm
Bennyis01
Yes error codes are readable but only saying lost communication with the body control module code U0140
Internal control module software incompatiblility
U0300
Thanks for your reply
Post #669673 23rd Jul 2023 10:15pm
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Had a similar problem, ended up replacing the module in the rear of the car. All good after that. Not saying it is the answer for your wheels, just my experience.
Post #669676 23rd Jul 2023 11:13pm
Bennyis01
Thanks for getting back ,it's looks as though it's heading that way , how much was a replacement if u don't mind me asking
Thanks
Jason
Post #669692 24th Jul 2023 11:39am
GraemeS
Australia
Which module has lost communication with the body control module?
Post #669693 24th Jul 2023 11:55am
Bennyis01
Not sure if it is height or suspension
Post #669698 24th Jul 2023 12:32pm
GraemeS
Australia
Suspension is height but there are several modules dependent on each other. Can you post the full picture of the DTC display? It should identify the particular module.
Post #669701 24th Jul 2023 12:59pm
Bennyis01
Those are only pics I have of fault codes the 1 states its body control module other than that I will try find more out later.
Post #669703 24th Jul 2023 1:57pm
Sonearly
I bought of eBay, paid £40 for it
Post #669726 24th Jul 2023 5:32pm
Bennyis01
Thanks for that mechanic has just ordered me 1 cost a little more but if it works I'll be happy
Thanks for your help 👍
Post #669730 24th Jul 2023 7:09pm
Bennyis01
Guys would just like to post that today was a happy ending finally for all the faults around adaptive dynamic fault
it was traced back to module in rear of car as Sonearly mentioned.
Module replaced ,wiring on suspension struts checked and tided up where required £285
A BIT DIFFERENT TO THE QUOTE i had last week of £2500 for ECU
Please don't take your first quote a gospel if possible shop around, there's ppl out there who care and understand the vehicles we have.
many thanks to all who have responded and advised, you've been a great help! Thumbs Up
Post #669888 26th Jul 2023 9:20pm
