![]() | Home > Technical (L405) > Charging system fault |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
I had this, I thought it was a dead battery, but it was an alternator failure. Red Triangle and Charging System Fault on Dash, then the battery drains and everything dies, entertainment system first then a whole raft of failures.
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
I also had 'charging system fault' during my car purchase from a dealer. They replaced both batteries due to 'low battery' persisting after I collected it. Unfortunately, without realising, when replacing the main battery they snapped the tiny wire that supplies a positive feed to the BMS control module on the negative terminal. Quick call to their contact at LR and they fixed it. Chris
