![]() | Home > In Car Electronics (L405) > SIM CARD & AirPlay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34976 ![]() ![]() |
i believe the panel just prises out...use a couple of flat head screwdrivers.. ... - .- -.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1117 ![]() ![]() |
There are 6 clips |
TomekW Member Since: 01 Jun 2023 Location: Warsaw Posts: 5 ![]() ![]() ![]() |
Hi, I was in similar situation 2 weeks ago
Great feedback TomekW |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 444 ![]() ![]() ![]() |
Many Thanks for the feedback. I set myself to remove it today. Murphy's Law was hard at work. Everything was working. So I haven't taken it out. Now I will look for this replacement part, so if I do take it out I can replace it immediately.
Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172 ![]() ![]() |
I had a range of cars F-Type / F-Pace / D5 and now the FFRR P400e.
The quote is €380 to replace it, I will decide closer to my service in October if I get it replaced - sooner if it starts having more issues. While searching the internet for this part, I saw a sticker on it that says "Replace if dropped", so I am thinking it will be better to get the garage to do this - labour is €80 of the quote - then the part is guaranteed for a year. SDV8 AB MY 2020
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 46 ![]() ![]() ![]() |
Hi All,
Have you done a code check?
No I can’t connect to web via Sim or via WiFi. But managed to do the infotainment update via the WiFi.
The fact you cant use the web browser right outside your home, on your home wifi, could mean you need the Vehicle shared secrets software installed, or its the TCU at fault. Hope you have JLR extended warranty? either way its a visit to the dealer or a switched on Indie 2018 SE SDV8 4.4 Byron Blue |
