![]() | Home > Off Topic - Other Cars > Some help please Discovery 4 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Highly likely to be a seized calliper or pins, strip down and lube or replacement time and yes, dont use it like this. BMW i3 Electric Car
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1447 ![]() ![]() ![]() |
Great, thanks for the swift response, I will get booked into garage immediately thanks AJGalaxay2012 |
When I used it the other day sounded like it had a stone in brakes, as when brakes used noise went away. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
That certainly sounds like brake caliper pistons not retracting as they should and holding the brake on for an extended period. The car has so much torque that it can drive regardless, sometimes with a shuddering through the steering, but the friction generates huge heat. I had exactly this on my 2004 322.
Thanks CS, I wonder if I should call recovery out and get them to free it so it can be driven to garage safely? |
That's what I would do. I'm happy to free motorcycle brakes, but am not confident about jacking the RR and working on the brakes without proper axle stands etc. Only Range Rovers since 1988 |
I agree, way out of my comfort zone. Thankyou CS |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
Had this a few times on my old 322.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
DrF
