Home > Technical (L322) > IID tool says Interior temp 215 C
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Having a bit of trouble with a/c. On the IID tool it says the internal temp of the car is 215 degrees C.
I assume it shouldn’t be that high and a sensor is a bit kaput.
Any pointers gratefully received!
Phil
Post #668279 4th Jul 2023 8:41am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I've had that on mine aswell. Outside temp & individual settings read correctly, but interior stated 215 degrees C.
It must be a default setting on the IID Tool. AC works fine, including Auto setting.
Post #668326 4th Jul 2023 3:42pm
garyRR
Iirc there are multiple live values you can trigger for cabin temperature - you just need to find the right one. I remember 2 of the variables saying they were but being the wrong ones. 2015 Range Rover Autobiography 4.4 SDV8
Post #668328 4th Jul 2023 4:03pm
Highroller
GaryRR, You're right, there are several selections you can make Thumbs Up
Post #668332 4th Jul 2023 4:29pm
philip1972
Thanks Gents
Post #668336 4th Jul 2023 4:55pm
