Home > Technical (L322) > Please Sir can I have some TPMS
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
After getting a blowout on the motorway I was forced to buy four new tyres and I included four TPMS valves in the deal but we couldn’t get it to work so I have included some photos of wear I think the transceivers think should be also above the centre console, which I removed. Can’t find the two PMS module. Does this mean mine hasn’t got it fitted and is there a way to fit it?
Post #667858 29th Jun 2023 1:54pm
dhallworth
TPMS was an optional extra on the later cars.
Our old 2007 TDV8 Vogue SE had it as standard. We learnt that our 2012 didn't have it fitted when we had a blue out on the A1 whilst towing a car on the trailer.
I looked at retrofitting it to our 2012 ages ago and ended up not bothering.
You'll need the 4 receivers that are plugged onto each wheel arch liner as per your pictures.
There's also a receiver that lives behind the head lining as you've mentioned.
I believe there is also a TPMS ECU somewhere.
Post #667860 29th Jun 2023 2:20pm
dhallworth
Here is a diagram of the system components from the workshop manual.
There is a receiver mounted to each wheel arch for the TPMS sensors, a receiver inside the car for the sensor mounted to the spare wheel, and an ECU in beside the rear fusebox.
Post #667912 29th Jun 2023 11:18pm
Simran0211
Thanks for the diagram would the wiring be installed on the cars or was it an optional extra
Post #667989 30th Jun 2023 4:03pm
The wiring might be there, unlikely that the sensors or ECU will be.
You'll also need an IID tool or similar to enable it in the CCF.
If you really want TPMS then I'd be inclined to just get a third party one - something like this - though I have no idea if it's any good......
Post #667998 30th Jun 2023 4:52pm
Simran0211
Thanks Alistair 👍👍
Post #667999 30th Jun 2023 4:57pm
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
I wouldn't bother tbh, and you'd need 5 sensors, you need one in the spare. Like I say, I wouldn't bother
Post #668217 3rd Jul 2023 2:40pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
You don't need spare wheel sensor. It can be disabled.
Post #668262 3rd Jul 2023 8:14pm
Byg Nyge
I did not know that. Over here in the UK it's an MOT failure if the car is of the year when TPMS if fitted has to work on all wheels including the spare. Thankfully mine is pre this date so a none functioning TPMS is not an MOT failure. (According to my MOT examiner of choice)
Post #668266 3rd Jul 2023 9:52pm
