![]() | Home > In Car Electronics (L322) > What really needed for Android headunit on '04 Vogue M62 |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 36 ![]() ![]() |
I have a 03 Vogue with DSP and the old BMW headunit. In my opinion the easiest solution is to move the old headunit into the glovebox because it is needed to activate the DSP. For the new unit you need one of those cables below. You need to check which connectors you have. The hardest part is getting the cables from the front to the back, that's what holding me off from doing it.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
May I humbly suggest that you preserve the original design by replacing the defective unit with a 2nd hand one? And if you want an actually usable navi, get a MKIV with 2019 maps. And if on top of it all you desire Bluetooth connectivity, plug a BMW module. All told should cost you probably less than half of an aftermarket Android unit + paraphernalia and it's all plug and play for the most part |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
Have a read of these…. I appreciate its not your original question…
