Home > Maintenance & Mods (L322) > How to check DPF status with IIDTool
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
I've no reason to suspect I've an issue, but I was curious about the status of the DPF as I've never seen a warning about it in the ~2 years I've owned the car...
Checking with the GAP, I looked at these readings and thought they seemed a bit strange...
Calculated soot 0g, ok, that's good, but seems very low.
"filter remaining volume" 0 also seems odd, is that normal?
Doesn't look like the service interval has been reset for 50k KM's, so the "distance to next service" is probably "fine" - for some value of fine.
Just curious whether this is normal and/or what values I should be looking at - as I said, no indications of issues with the car and no other fault codes. Just curious Smile
Post #667070 19th Jun 2023 8:57pm
Range Rover L322
It is a gigantic topic. This post will give you a solid understanding although if you don't have an issue, I would not bother!
https://www.fullfatrr.com/forum/topic48068.html?highlight=dpf 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #667077 19th Jun 2023 10:52pm
DrRob
As above, no amber or red light then don't go down the rabbit hole Rolling with laughter
Most of the fields you've chosen there are no use at all.
Oil dilution is one to look for.
Read the thread highlighted and you'll wish you never bought a DPF fitted car Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667084 20th Jun 2023 6:28am
Siftah
I'm getting *very* strong, "if it ain't broke, don't try to fix it" vibes and you guys are usually right so...
I'm not even going to read that topic haha Smile
Post #667085 20th Jun 2023 6:31am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The DPF is a filter.
IMO, to say "if it ain't broke, don't try to fix it" when it comes to a filter is not the right thing to do.
Just add the word 'oil' or 'air' in front of 'filter' and see if you get the same reactions.
Most likely not and rightfully so.
Sure, you can drive and drive and drive and think everything is ok as long as I don't get any warnings.
Kinda like sticking your head in the soot Wink
Every filter will be full at some point.
To replace an oil or air filter is easy and cheap.
To replace a DPF may be easy, I mean, how many bolts to undo to remove the exhaust system, but it will not be cheap.
Whistle 2012 4.4TDV8
2000 Honda S2000
Post #667088 20th Jun 2023 8:00am
JayGee
The DPF is self cleaning so it's not at all like an oil or air filter. 2012 TDV8 Vogue (L322)
Post #667097 20th Jun 2023 9:15am
SpitfireS
Quote:
JayGee Posted on 20th Jun 2023 11:15am
"The DPF is self cleaning so it's not at all like an oil or air filter."
Well... yes, but actually no.
Wink
The regeneration cycle turns the soot into ash, so yes it removes the soot.
The ash stays in the filter though, no on-board regeneration is able to remove the ash.
Lets say, for arguments sake, the ratio of soot to ash is 100:1
A 100% full-with-soot DPF will turn into a 1% full-with-ash DPF.
This means the DPF can hold only 99% soot.
During the next regeneration this 99% soot is turned into 1% ash again.
Now the DPF has 2% ash and can hold 98% soot.
And so on and so on and so on...
At some point the DPF will be full enough with ash for the ECU to say "It's done"
And then it gets expensive. Big Cry 2012 4.4TDV8
2000 Honda S2000
Post #667117 20th Jun 2023 12:12pm
DrRob
Agreed but only if you get an amber or red warning should you worry. Otherwise, drive it and enjoy it Whistle Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667120 20th Jun 2023 1:12pm
DrRob
And then just cut it out, blank and map out the EGR. Then, remap it and move on Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667121 20th Jun 2023 1:13pm
JayGee
Wink
That will be at very high miles unless you have another fault so again it's nothing like an air or oil filter. It's more like any other component which will wear out in time such as a gearbox or shock absorber or wheel bearing.... 2012 TDV8 Vogue (L322)
Post #667130 20th Jun 2023 5:27pm
JayGee
until the MOT inspector fails it. Thumbs Up 2012 TDV8 Vogue (L322)
Post #667131 20th Jun 2023 5:28pm
SpitfireS
Imho: no.
Besides, what's high miles in your opinion?
When you drive 120.000km with a DPF it will fill up with ash and there is no other fault needed for this to happen.
And one can be sure it will happen earlier if you drive only short distances and/or city miles.
If one plans to keep the car for a while, cleaning the DPF off-board, so to speak, is IMO part of routine maintenance.
It's what you get driving a car with a DPF, it's something they don't mention when you buy the car.
That this is a 4 year routine - in my case - doesn't mean it's not a routine.
And I don't plan to change my gearbox ever, to be honest.
Especially not after having it flushed at 130.000, also something Landrover doesn't mention but ZF does recommend.
The air (front) springs probably need replacing in 10 years (as mentioned by many on this forum) or maybe wheel bearings if an alignment shows they are done.
AFAIK my 11 year 215000km old shock absorbers are fine.
Smile 2012 4.4TDV8
2000 Honda S2000
Post #667226 21st Jun 2023 1:48pm
SpitfireS
You sound like that guy that jumped out of a 50 story building.
People could hear him say at floor 15, as he rushed by: "So far so good!"
Passing floor 5 he got the amber warning Laughing
Passing floor 3 he got a red warning Twisted Evil
Time to open the parachute, right?
Thumbs Up Very Happy 2012 4.4TDV8
2000 Honda S2000
Post #667227 21st Jun 2023 1:52pm
I know a guy with 350,000miles on the 4.4 diesel, he's never had to replace the DPF but he has had a new gearbox and several sets of shocks, among other things... maybe it's the way he drives... Pete
Post #667247 21st Jun 2023 5:22pm
