Home > Technical (L322) > P040D-00 - EGR temperature sensor A - circuit high (2B) |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 185 |
I’m keen to nail this down too. I don’t have that fault code and never have, but do have EGR issues atm so am on my own investigative journey to discover how the system works and what triggers what.
19th Jun 2023 6:05pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4287 |
Gary - it might be in the Wiki iirc 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Jun 2023 9:32pm |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 68 |
Gary, I have exactly the same fault conde on my 2011 4.4tdv8, only saw the fault when using my GAP iid tool haven't had any warnings on dash but have the fault code on the iiD. Did you get anywhere with yours? Current 2011 4.4TDV8 VSE 1972 MGBGT Gone 2004 Discovery Landmark 2.5D 2003 Freelander TD4 SE |
25th Jun 2023 8:37pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1452 |
Mine's been intermittent for some time but now returns as soon as I clear the fault. Again, no issues flagged on the dash.
25th Jun 2023 8:40pm |
Ok, I have only had the car just over a week, its going in to a local specialist and I will sound him out about it and report what he says if its worth replacing the sensor or just ignoring the fault. Current
25th Jun 2023 8:43pm |
Craig5 Member Since: 05 May 2023 Location: Liverpool Posts: 42 |
Surely it has to affect Dpf as doesn’t the regen work off the exhaust temp as when to work? |
26th Jun 2023 10:09pm |
There's 4 different exhaust gas temperature sensors - the ECU will likely be programmed to take the readings it has and take a default value for a faulty sensor.
26th Jun 2023 10:15pm |
I have a Dpf full warning and only other fault I have on gap is temp sensor and on a run my soot count is rising |
26th Jun 2023 10:19pm |
So as an update have a egr error code not giving restricted performance at present but apparantly could on a long run, I went to a 4x4 specialist who has advised that it's not a sensor and that in fact he advised to replace the throttle body, just thought I would share this. Collecting a new throttle body today from main dealer so will update again if this fixes the issue. Current
11th Jul 2023 7:25am |
To fix a P040D-00 error code or a different code?
11th Jul 2023 8:27am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
There is 6 gas temp. sensors. |
11th Jul 2023 11:48am |
MarkyK Member Since: 31 Aug 2024 Location: Cheshire Posts: 5 |
Hi Gary do you have a new link to the guide please? I have the P040D error but The link above isn’t working anymore Many thanks Mark |
31st Aug 2024 2:30pm |
