Home > Technical (L322) > Gearbox in manual mode to rule out TC issues?
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
I have seen many people say that if you have a vibration when going uphill at low speed that doesn't go away when the gearbox is it sports mode then that rules out torque converter issues - the theory being the TC clutch is locked into place...is this true?
Post #666629 15th Jun 2023 5:39am
RRPhil
I find that a more reliable indicator is to very closely watch the rev counter needle while the vibration is underway to see if it moves up and down in sympathy with the noise, indicating stick-slip of the lock-up clutch. The variation is only a couple of hundred rpm or so, hence the need to look closely.
Phil
Post #666689 15th Jun 2023 3:35pm
