![]() | Home > Maintenance & Mods (L322) > How do I check/test suspension arms and joints? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
A couple of ways to check are - visually inspect the arms, are the rubber boots ( where fitted ) still in good order. On some arms etc it is possible to see the rubber bush, to see if there is any degradation of the rubber. Use a pry bar to lever the arms etc to see if there is any play.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Cheers Mercy, thats great |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Make sure car is safely supported on suitable axle stands remember they weigh nearly 3 tonnes!
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Morning Steve, hope life is treating you well...
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Mine don't make any thuds or bangs but the front front arms have gone, the ball joints in the front rear arms have slightly play, and the rear drop links have play... yet no symptoms.
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 150 ![]() ![]() ![]() |
My nearside tyre is wearing on the outer tread which could suggest mis-alignment however, also produces a "bang on the same side when I drive over a road hump of a size but the offside has no problems re bangs or odd tyre wear.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
usually, its the anti roll bar tie rods that go first, easy to change, sometimes you notice a click or noise in reverse.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
163k
Would be good, but rusty Sills to do first! |
