Home > Technical (L322) > 2010 L322 Rear Door Superlock? (Cannot open)
JacquesFury
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
One of my L322’s has a completely dead rear door.
- interior and exterior door handle do not operate it
- no noise from actuator when lock or unlock
- the doors switch or drivers panel switch does not operate the window.
- no fault codes
- no visible damage to the wiring loom
Yes I’ve reset the battery, yes I’ve checked the BDC for codes, one mechanic reckons it’s just a seized latch. But too me that doesn’t explain the lack of mechanical noise or the window not operating through any switches.
I don’t think it can be the child lock? Because the drives door switches would be Abel to operate the window?
Just the one rear left door... thanks for any help
Bow down Bow down
Post #665807 3rd Jun 2023 2:07pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I had this exact problem with my rear door and I finally found that the child lock lever had somehow detached itself from the mechanism but was still floating around in the lock. I had to pull the tread plate up and then unscrew the door card (that will move but won’t come out) and then carefully pull the door seals away to get some access. You’ll need a longish screwdriver to pry the child lock part away (if this is the same problem of course).
A word of warning… you’ll most likely be inside the car doing this and when it lets go you’ll likely be leaning on the door so don’t fall out like I did…. Laughing
Good luck
Regards
John
Post #665852 4th Jun 2023 7:23am
